Date/Time: Sun, 05 May 2024 17:50:34 +0000
[User Discussion] - DOM Template
View Count: 7135
[2020-10-25 14:18:42] |
Bruce - Posts: 46 |
Looking for a Dom template similar to Jigsaw, that can be modified and changed. any assistance would be appreciated Thanks |
[2020-10-25 22:32:11] |
User235292 - Posts: 10 |
http://www.sierrachart.com/image.php?Image=1603665029673.png
Attachment Deleted. RTH.Cht - Attached On 2020-10-25 22:27:11 UTC - Size: 19.99 KB - 910 views |
[2020-10-25 22:50:03] |
He you have Jigsaw, ATAS, and one more http://www.sierrachart.com/image.php?Image=1603665924506.png |
Chartbook1.Cht - Attached On 2020-10-25 22:48:25 UTC - Size: 9.69 KB - 1553 views RTH.Cht - Attached On 2020-10-25 22:49:54 UTC - Size: 19.99 KB - 1176 views |
[2021-10-12 20:29:51] |
PlainCheesePizza - Posts: 17 |
Thank you for sharing these, is there a way to reset the data like you can in jig saw?
[2021-10-12 20:53:49] |
Yes, you can customize your own keybord shortcuts in Global Settings-Keybrd Shortcuts-Trade-Clear curent Bid/Ask or Clear recent bid/ask, also usefull recenter dom
[2022-12-20 23:57:42] |
Hiroshigawa - Posts: 3 |
HI User235292, I downloaded you templates and loaded them in my Sierra but the text sizes are really small i'm not able to find where to change them. Could you please help. See image |
Untitled 9.png / V - Attached On 2022-12-20 23:55:57 UTC - Size: 605.6 KB - 556 views Attachment Deleted. |
[2023-01-02 01:57:29] |
User344261 - Posts: 3 |
Go to global graphics setting, then under fonts adjust the fonts for TradeDOM quantities.
