Date/Time: Thu, 02 May 2024 21:19:41 +0000
Correlation/ Overlay chart
View Count: 1404
[2014-02-12 06:41:53] |
vrunrun - Posts: 53 |
Hello SC, I know that SC can plot correlation chart e.g. on different index prices. Just wonder if it's possible to plot a correlation chart to show indicator e.g. ATR of different index/ symbols. Thks. |
[2014-02-12 07:06:30] |
Yes. For example, if you are using the Ratio study, then you will want to set Display as Main Price Graph in the Study Settings window for the study.
[2014-02-12 17:19:15] |
Yes, I got it. Thks.
