Date/Time: Sat, 21 Nov 2026 10:39:49 +0000
Restore Trades
View Count: 836
| [2020-10-22 02:25:12] |
| User313304 - Posts: 1 |
Good morning, I had a problem and I had to change my computer. So I had to log in and install everything again. I would like to know if I can make all the trades that I have taken before appear on the chart. Thanks |
| [2020-10-22 02:39:06] |
I would like to know if I can make all the trades that I have taken before appear on the chart. This is only supported when using the Sierra Chart Order Routing Service which we recommend that you change to. Documentation:Sierra Chart Order Routing Service Let us know if you need help to change to this service. Be aware that you will only be able to access historical trading activity for trading activity you have done on this service. Not what you have done on CQG. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
