Date/Time: Mon, 29 Apr 2024 18:20:27 +0000
SL Move
View Count: 487
[2020-10-18 17:05:37] |
User231861 - Posts: 9 |
Hi ,i'm sorry to disturb for somrthing for you very easy to do...i'm sure . But i don't arrive to set a SL that move after breackeven of X ticks . For example i have SL 10 TICKS tp 10 TICKS After my entry price is in gain of x ticks Move SL of X ticks . Thank you very much for your help ! |
[2020-10-19 14:51:20] |
Attached is an example for how to do this. Follow the instructions here: Attached Orders: Step-By-Step Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
User231861_twconfig.png / V - Attached On 2020-10-19 14:50:20 UTC - Size: 8.03 KB - 179 views |
