Date/Time: Fri, 03 May 2024 13:36:45 +0000
High + low +close / 3 study?
View Count: 1211
[2014-02-11 12:09:55] |
User66360 - Posts: 81 |
I'm looking for a plotted point on my charts that is as simple as High + low +close / 3? Its almost like the pivot range but only the first point. Id like to to show a single point/dash/dot,etc on my charts. It would be based on the daily, one single dash for each day. Is this somewhere and I haven't seen it? or can it be programmed? thanks
[2014-02-11 15:33:25] |
Sierra Chart - Max - Posts: 5599 |
You will want to create a spreadsheet study following the steps here: http://www.sierrachart.com/index.php?l=doc/doc_StudiesSystemsAlerts.php#StepbystepInstructions In Cell K3, you can use a formula similar to the following: =(C3+D3+E3)/3
Sierra Chart Support |
[2014-02-11 17:12:22] |
I am not good at all with that sort of thing. Completely lost... Thanks for the response
[2014-02-11 17:18:31] |
Another way to do this is to add a Moving Average-Simple study to the chart and set the Length input to 1. Set the Input Data study input to HLC Average.
