Date/Time: Tue, 30 Apr 2024 19:39:10 +0000
is there any recommended feed for china and india indexes with bid/ask data?
View Count: 1199
[2014-02-11 10:55:03] |
ariknoi - Posts: 31 |
[2014-02-11 18:11:24] |
Not sure about China and we do not know what exchange you are referring to. For Indian markets Sierra Chart does support Global Data Feeds: http://www.sierrachart.com/index.php?l=doc/GlobalDataFeeds_India.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-11 18:36:37] |
User51517 - Posts: 58 |
For China market, I would recommend Wind Information Co., Ltd. But I don't think it's supported on SC. Some brokers cover Hang Seng index in Hong Kong. That's the closest you can get. I know nothing about India market. |
[2014-02-11 18:38:39] |
thanks!
[2014-02-12 06:32:46] |
vrunrun - Posts: 53 |
Can you advise which broker covers Hang Seng Index in Hong Kong? Thks.
[2014-02-12 13:10:36] |
Straits Financial in Chicago
[2014-02-12 17:17:49] |
Thanks but what I want is to use the data with Sierra Chart and it sseems that Straits Financial can't do that (correct me if I'm wrong). I know that it is feasible via Interative broker but I would like to know more alternatives before making the decision. Any recommendations?
