Date/Time: Sun, 28 Apr 2024 23:45:43 +0000
Chart DOM - colour of text values
View Count: 1053
[2014-02-11 07:31:31] |
User13668 - Posts: 291 |
Hi there, How do you set the text value colour to stay as 'black' even when the value is a blocked colour due to representing some price value from a study. See attched. You can see the text value colour changes from black to grey when that value is a colour highlighted box. Trouble is grey text value font on a light coloured background is hard to read. |
Chart DOM.JPG / V - Attached On 2014-02-11 07:31:01 UTC - Size: 25.44 KB - 346 views |
[2014-02-11 08:22:47] |
You cannot. The Text color itself cannot be controlled. It is the same as the background color.
