Date/Time: Thu, 02 May 2024 16:00:56 +0000
Watchlist with additional info
View Count: 1071
[2014-02-10 21:23:00] |
User98465 - Posts: 12 |
Hi, i have been searching for an answer among other topics but couldn't find one. How can I have some additional data in Watchlist window such as daily movement in price and in percentage. Example if fx pair EURUSD is down 100 pips I would like to see -0.100 and -0.7x%. It would be great to see even more such as the number of indicator ATR for last 5 days seen in this table as well, etc. But I won't complicate with that now I would just like to see daily moves (with red or green color. Now I have to use other applications to see that. I may have failed with searching this, but still I did not find it. Thank you! |
[2014-02-10 22:41:47] |
We see you are using the SC Forex Data (FXCM) service. We have just implemented support for the Net Change values. You can add these fields through Global Settings >> Customize Chart Header. These values may not always be 100% correct. Most of the time they will be. It would be great to see even more such as the number of indicator ATR for last 5 days seen in this table as well, We do not ever foresee this being offered. This is very complex to implement, problematic and fundamentally from our perspective makes no sense.Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
