Date/Time: Sat, 04 May 2024 00:26:14 +0000
US Dollar index data patchy
View Count: 1247
[2014-02-10 21:07:37] |
bwalks123 - Posts: 122 |
I found the US Dollar Index today which I was unaware came with SC $35 real time data feed and it seems to be missing a lot of data compared to other feeds? I loaded the Mar14-ICE_IPE contract and data just seems to be wrong when loading a range or tick chart!
[2014-02-10 21:12:23] |
No. ICE is not included in the $35 market data fee. You have to pay the ICE exchange fee. The data you are getting for the US dollar index is from AMP/TTNet. You can tell because you will not see a [M] after the symbol at the top of the chart.
[2014-02-11 03:08:53] |
Oh ok thanks that makes sense. I have now pulled up a gold GC-201404 [M] 8 range chart and it is missing data? Here is a screen shot attached. I have tried to delete all data and download but still missing data. http://www.sierrachart.com/Download.php?Folder=SupportBoard&download=2024 |
Gold range chart missing data.PNG / V - Attached On 2014-02-11 03:08:15 UTC - Size: 97.42 KB - 574 views Attachment Deleted. |
[2014-02-11 03:23:17] |
If you want want to show us missing data, we should not be presented with a chart like that. It needs to be a chart based on minutes like 5 minutes per bar in the case of an Intraday chart and it needs to contain no studies. By using Range bars, you add a whole layer of complexity that raises questions as to what it we are being shown. We have checked the servers and we do not see any missing data for Gold 2014 April for 2014-2-10. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-11 03:24:06
[2014-02-11 03:38:48] |
My apologies, thanks for the confirmation on the correct data. Much appreciated.
