Date/Time: Sun, 05 May 2024 10:21:47 +0000
Is There An Indicator That Draws a Line for the HL Average for a Time Period?
View Count: 991
[2014-02-10 17:27:34] |
User25633 - Posts: 10 |
I see there is an indicator called the High/Low for Time Period but I would also like to draw a line that shows the High and Low average of that same time period. Is there an indicator I can use to accomplish this? Thank you.
[2014-02-10 18:18:56] |
Yes. Use the Study Subgraphs Average study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s164 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
