Date/Time: Mon, 29 Apr 2024 11:56:26 +0000
E7 intraday data not showing
View Count: 2138
[2013-04-17 22:29:26] |
User268601 - Posts: 28 |
I'm trying to get an intraday chart for the e-mini euro, symbol E7. Daily chart works. Intraday is blank. I've traded the product before through my rithmic r trader and now want to trade it here. I've seen a similar thread listed in support here but it did not solve my issue. Hoping you can assist me. Thanks |
[2013-04-18 05:08:27] |
We are checking on this.
[2013-04-18 06:03:27] |
Please restart Sierra Chart and you will now see the symbol listed in File >> Find Symbol. Select the symbol and you should get a chart. Could you let us know who your broker is? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-18 09:01:31] |
My broker is deep discount trading. I do now see the symbol but there still isn't an intraday chart. Daily still works though but intraday is still blank.
[2013-04-18 20:04:05] |
We had to correct the symbol. This is the correct symbol to use: E7M3-CME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-18 20:17:11] |
It still reads as "7E" in the symbol list after a reboot but I do have intraday data now.
