Date/Time: Sun, 19 May 2024 16:56:40 +0000
Fees
View Count: 623
[2020-10-09 15:20:42] |
User575399 - Posts: 305 |
Hello, I was wondering what Data fees I may be paying that I don’t need/use . My main instrument is ES and MES live data . Are their fees I may be able to cut ( ie NYMEX)but still maintain live ES/MES? Thank you |
[2020-10-09 16:32:29] |
John - SC Support - Posts: 31733 |
Do you need Market Depth data?
[2020-10-09 16:37:47] |
Yes.
[2020-10-09 16:51:25] |
Then you could change the particular exchange that you have activated. Instead of the "Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts" exchange, you would use the "CME with Market Depth for nonprofessional Trading accounts" exchange. This will still give you the ES and MES along with others that are on the CME and Globex. Just be aware that you have paid for the exchange in full for the month, so you do not want to make a change until the beginning of next month. Prior to the end of this month, you need to select the option to "Deactivate" the "Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts". This just sets it to not renew, you will still have access through the end of the month. You will do this on this page: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Then on November 1, go to that same page (above) and enable the "CME with Market Depth for nonprofessional Trading accounts" exchange. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-09 16:53:18] |
How much would that save me ?
[2020-10-09 17:07:30] |
You are currently paying $31.20 for the Full CME Group. The CME with Market Depth exchange is $10.40. So a saving of $20.80 per month. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-09 18:05:44] |
Ok I have to think about it . Thank you !
[2020-11-01 15:25:26] |
Just to be clear, if I want to just have CME with market depth I deactivate "full CME " and activate "CME market depth" at the same time? This will be a seamless transition with no data down time ?
[2020-11-01 15:32:07] |
Yes this is correct, but we are already in a new month, so you have already paid this month for the Full CME Group with Market Depth data.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-01 15:32:19
[2020-11-01 21:01:53] |
So I deactivated "Full CME " and activated "CME with market Depth. " I noticed when I open my chart book the green connection icon at the top left is missing. Is this normal and why is it missing now? pic attached |
Screenshot (2).png / V - Attached On 2020-11-01 21:01:37 UTC - Size: 21.6 KB - 174 views |
[2020-11-02 05:02:14] |
You need to add that. Refer to: Status Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
