Date/Time: Mon, 13 May 2024 21:32:44 +0000
Indicador TICKCOUNTER
View Count: 504
[2020-10-09 13:57:36] |
User456598 - Posts: 27 |
cordila saludo, quisiera saber si en sierrachart encuentro el indicador TICK COUNTER, gracias. |
[2020-10-09 14:47:32] |
John - SC Support - Posts: 31598 |
From Google Translate: cordial greeting,
I would like to know if I find the TICK COUNTER indicator in sierrachart, thank you. We are not sure what you mean by "Tick Counter" indicator. If you are referring to tick charts (number of trades), then this is fully supported. Refer to the following for the different ways you can setup your charting: Chart Settings: Time Period Per Bar / Amount of Data Per Bar (Chart >> Chart Settings >> Bar Period menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
