Date/Time: Tue, 30 Apr 2024 09:11:31 +0000
How do I program multiple entries on spreadsheet trading???
View Count: 1139
[2014-02-10 15:56:25] |
User14682 - Posts: 83 |
How do I program multiple entries and exits. 1st trade : =AND(AA3>AG3,AA4<AG4,E3>AC3,AG3>AE3,AG3>AI3) = 3 LOT second trade : =AND(AA3>AE3,AA4<AE4,E3>AC3,AE3>AG3,AE3>AI3) = 2 LOT |
[2014-02-10 17:40:48] |
You need to set Allow Multiple Entries in Same Direction to Yes: http://www.sierrachart.com/index.php?l=doc/doc_AutoTradeManagment.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-10 17:43:53] |
How do I control the size??? and provide an exit for each?
[2014-02-10 18:22:38] |
This is done through the Order Quantity cell: https://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#CellJ26 And refer to this section here: https://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#AutomatedTradingExample Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
