Date/Time: Wed, 15 May 2024 17:22:51 +0000
Sierra Chart on Samsung Galaxy Tab 7 Plus
View Count: 753
[2020-10-08 12:45:43] |
MuUs! - Posts: 45 |
Hello, I was wondering if it was possible to install the Sierra chart software directly on the Samsung Galaxy Tab 7 Plus. This version of tablet features the Samsung Dex application which converts the tablet mode into a full desktop experience, which allows to run Windows applications on it. I would like to know if it was possible to install the Sierra Software on it. Thanks for the support. |
[2020-10-08 19:50:29] |
We are not sure. Give this a try. If that device runs Windows it should work so long as the CPU is of this type: https://en.wikipedia.org/wiki/X86-64 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-08 19:50:44
