Date/Time: Sat, 21 Nov 2026 10:55:42 +0000
New Drive
View Count: 794
| [2020-10-07 04:48:53] |
| User78442 - Posts: 260 |
Hi, my C-drive is near capacity due to the size of my SC Data & Backups. I would like to add a new Drive and store these two folders on it while running SC on the existing C-Drive. Is this possible? Are there any other folders/executables that need to reside on the new drive?
| [2020-10-07 14:08:57] |
| John - SC Support - Posts: 48610 |
You can change the Data Directory but not the Backups. Refer to the information here: General Settings Window: Data Files Folder (Global Settings >> General Settings >> Paths >> Files and Folder Paths) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-10-07 18:46:16] |
In the Backups folder, you can just delete any files you do not need in there. That should not be a big folder. Really Sierra Chart should be on its own dedicated solid-state drive.
| [2020-10-08 05:18:21] |
OK agreed, I've just bought a couple of SS Drives and will move the complete installations over. Thanks for your input.
