Date/Time: Sat, 18 May 2024 16:14:38 +0000
Rithmic Bridge
View Count: 1290
[2020-10-07 01:11:16] |
User423419 - Posts: 15 |
Hi, I have Denali data which I use for my live trading, but I'd like to get evaluated with Oneup also. I don't want to use another platform as I love what sierra chart has to offer and it's what I'm used to. I can't figure out this bridge thing. Is there any way I can pay you guys to remote in or something and help me get it set up on my computer? I would really appreciate the help.
Date Time Of Last Edit: 2020-10-07 01:14:14
[2020-10-07 14:54:47] |
Here is the link: Rithmic Bridge Files For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-08 09:57:23
[2020-10-11 21:16:45] |
Does this look correct? I downloaded the files and then extracted them. I'm shit with computers, so trying to figure this out. I know you guys don't want to deal with Rithmic issues, but it'd help me out a lot. As stated previously, I'd be more than happy to just payu a fee for you guys to remote in and get the files corrected for me. I attached pictures of the files in the rim folder, as well as the error I'm getting from sierra chart when I try connecting. Thanks again |
Rithmic Bridge.PNG / V - Attached On 2020-10-11 21:16:14 UTC - Size: 14.44 KB - 343 views Rithmic Bridge not connecting.PNG / V - Attached On 2020-10-11 21:16:21 UTC - Size: 23.05 KB - 315 views |
[2020-10-12 13:48:11] |
Copy all the files in the directory that you currently have them (they are currently in C:\SierraChart\Rim\RithmicBridge) then go up one level and paste them there (the directory you need to paste them into is C:\SierraChart\Rim).
[2020-10-12 15:26:12] |
That worked, thank you
[2021-10-11 10:35:24] |
User535866 - Posts: 3 |
Hello, i have past die 4 files in C:\SierraChart\Rim and restarted sierra chart. but Rithmic trading is not listed in the list of services. I have the current version of sirra chart. Can somebody help me? thanks a lot! Update: i installed the version 2296 and now it works |
[2021-10-11 14:41:12] |
The old "Bridge" files method for connecting to Rithmic is no longer supported. You need to use the new interface that has been developed by Rithmic. To do this, follow the Setup Instructions at the following link: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
