Date/Time: Mon, 29 Apr 2024 09:54:25 +0000
$tick Alert
View Count: 2017
[2013-03-21 20:24:28] |
User41288 - Posts: 13 |
Hi all, I am trying to create this simple alert condition for my 1 minute $tick chart. Its not working though I followed the $tick alert example from SC.I am getting error messages in log window. My alert formula is as below: =OR(CROSSOVER(C,-790),CROSSOVER(C,790) Alert Sound is Alert1 & have tried the boxes checked & unchecked under chart settings. Please help !!! |
[2013-03-21 20:45:24] |
What is the Alert error text you are getting? Please provide the exact text of it. You can select the line in the Alerts Log and press Copy Selection to copy it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-03-21 20:45:53
[2013-03-21 21:42:01] |
M5amhan - Posts: 468 |
i think you are missing a parentheses at the end .. try using this =OR(CROSSOVER(C,-790),CROSSOVER(C,790)) |
