Date/Time: Sun, 05 May 2024 18:57:45 +0000
Tick Chart
View Count: 1035
[2014-02-09 12:49:00] |
User15952 - Posts: 132 |
How do you display a tick chart. The lowest time frame I can find is 1 second? I am using the realtime CME data. Thanks |
[2014-02-09 18:41:18] |
StAloyboy - Posts: 11 |
Hi User15952, Click on a chart and then on your keyboard press the number 1 and then the letter t and you will have a one tick chart. |
[2014-02-09 22:26:43] |
Here is the documentation for this: https://www.sierrachart.com/index.php?l=doc/doc_KeyboardCommands.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
