Date/Time: Tue, 08 Jul 2025 10:16:46 +0000
[User Discussion] - New kiwi's stuff for 2020+ 🇳🇿 🎆 🎇 🎆 🇦🇺
View Count: 1564
[2020-10-02 00:11:13]
Kiwi - Posts: 375
From a post on the main board. Here's a better version ... and the start of a new kiwi's stuff, kiwi_20. This one permits you to select 3 times (just duplicate a time or use an untraded time if you don't need 3). Modifying it should be easy if needed 🙂
SCSFExport scsf_RecalcChartAtTimes(SCStudyInterfaceRef sc)
if (sc.SetDefaults)
sc.GraphName = "RecalcAtTimes";
sc.StudyDescription = "Recalc At Specified Times";
sc.GraphRegion = 0;
sc.Subgraph[0].Name = "Strobe";
sc.Subgraph[1].Name = "dbg 0";
sc.Subgraph[0].DrawStyle = DRAWSTYLE_IGNORE;
sc.Subgraph[1].DrawStyle = DRAWSTYLE_IGNORE;
sc.Input[1].Name="Also reload chart data";
sc.Input[1].SetYesNo(0);
sc.Input[2].Name = "Time to Recalc";
sc.Input[2].ValueType = TIME_VALUE;
sc.Input[3].Name = "Time to Recalc";
sc.Input[3].ValueType = TIME_VALUE;
sc.Input[4].Name = "Time to Recalc";
sc.Input[4].ValueType = TIME_VALUE;
return;
int& bar_is_tested = sc.GetPersistentIntFast(0);
// This will test if this bar has been checked and if not
// it will test if the bar includes one of the times
// and if it does: recalculate and reload if chosen
if (sc.ArraySize != bar_is_tested)
bar_is_tested = sc.ArraySize;
int this_ = sc.BaseDateTimeIn[sc.ArraySize-1].GetTime();
int next_ = sc.BaseDateTimeIn[sc.ArraySize-1].GetTime() + sc.SecondsPerBar;
if ((sc.Input[2].GetTime() >= this_ && sc.Input[2].GetTime() < next_) ||
(sc.Input[3].GetTime() >= this_ && sc.Input[3].GetTime() < next_) ||
(sc.Input[4].GetTime() >= this_ && sc.Input[4].GetTime() < next_))
sc.Subgraph[0][sc.ArraySize-1] = this_;
sc.FlagFullRecalculate = 1;
if (sc.Input[1].GetYesNo())
sc.FlagToReloadChartData = 1;
compiled for SC 2175
Date Time Of Last Edit: 2020-10-02 00:17:44
attachmentkiwi_20.cpp - Attached On 2020-10-02 00:16:41 UTC - Size: 1.69 KB - 414 views
attachmentkiwi_20_64.dll - Attached On 2020-10-02 00:16:55 UTC - Size: 891 KB - 439 views
[2020-11-06 01:17:14]
Kiwi - Posts: 375
Just been asked about a script I posted to convert scid to csv (User681150, can you post a link to the original post) which had stopped working.
I just tried this version with Python 3.8 and it worked when I inserted a filename at line 91. So hopefully its good in your environment. If not, ask.
attachmentSCID_to_CSV.py - Attached On 2020-11-06 01:15:49 UTC - Size: 3.76 KB - 489 views
[2020-12-18 01:00:10]
User681150 - Posts: 62
hello, i am getting an error, saying i need a buffer of 40 bytes... any idea?
Traceback (most recent call last):
File "C:/Users/MTS/Downloads/SCID_to_CSV.py", line 107, in <module>
convertRecords(filename, filename[:-4] + 'csv', tzvar, 1)
File "C:/Users/MTS/Downloads/SCID_to_CSV.py", line 75, in convertRecords
dataRow = struct.unpack('d4f4I', data)
struct.error: unpack requires a buffer of 40 bytes
[2022-08-12 18:19:20]
RMF2 - Posts: 43
Hello
I'm getting an error on the code. Could you please give some tips on where to look for the string error?
ValueError Traceback (most recent call last)
~\AppData\Local\Temp/ipykernel_16260/2227147715.py in <module>
99 print(tzvar, type(tzvar))
100 else:
--> 101 tzvar = float(sys.argv[2])
102 print(tzvar, type(tzvar))
103 # filename = 'all' ############## remove ##########################
ValueError: could not convert string to float:
