Date/Time: Sat, 21 Nov 2026 10:55:43 +0000
Study Subgraph above/below bar, Ask/Bid diff for pullback column
View Count: 946
| [2020-10-01 09:19:45] |
| User884550 - Posts: 149 |
Pls advise how to make ask/bid vol bar to show up also for numbers bars pullback column? see attached
| [2020-10-01 14:41:12] |
| John - SC Support - Posts: 48610 |
That is not supported. The best you could do is to use the Numbers Bars Calculated Values and set the Input for Show Pullback Column Values. Refer to the information here: Numbers Bars: Numbers Bars Calculated Values Input Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-10-03 11:11:21] |
We will see if we can add support for this in the next release.
| [2020-10-08 07:34:35] |
cant see if this has been done yet? any ETA? |
