Date/Time: Wed, 01 May 2024 04:25:13 +0000
Custom import data file points for S/R zones
View Count: 1208
[2014-02-08 20:41:48] |
emp0804 - Posts: 31 |
Support, I use three different chartbooks and would like to enter the S/R ranges once for all three chartbooks. Could I create one import file that contains price ranges of S/R zones using extending rectangles? If so is there any documentation to do this? Thanks for your time! |
[2014-02-10 10:06:17] |
You may want to look at using the Spreadsheet Study. You can enter values directly on that to display Support and Resistance lines on a chart. Here is the documentation: https://www.sierrachart.com/index.php?l=doc/doc_WorksheetStudy.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
