Date/Time: Sun, 05 May 2024 18:11:56 +0000
Some Upgrade Suggestions for Sierra Charts
View Count: 999
[2014-02-08 14:57:48] |
User47503 - Posts: 2 |
A few suggestions, > > > One, have the Option to add weekend data to the charts even if it is just dashes, for Saturday and Sunday > > This way the Cycles are not off using the Cycle tool on the Chart do to Saturday and most of Sunday Data Missing. > > > Have a Jump To Feature where one can type in a Specific date and time and it will jump > > right to it, instead of having to scroll back in time. As if one is doing so on a 1 minute time > > frame going back 6 months to a year it can take a long time. > > > Another, When a Trend Lines are drawn on any time frame they transfer to all time frames. |
[2014-02-11 10:21:38] |
Thank you for the suggestions. You can jump to a particular Date-Time through Chart >> Goto Date-Time. You can copy Chart Drawings from one chart to another chart. Refer to: https://www.sierrachart.com/index.php?l=doc/helpdetails72.html > Another, When a Trend Lines are drawn on any time frame they transfer to all time frames. Maybe we have misunderstood this. Can you explain this further.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-11 10:23:01
