Date/Time: Tue, 21 May 2024 22:47:10 +0000
SC supports Linux OS?
View Count: 1663
[2014-02-08 11:13:03] |
batman_ - Posts: 190 |
Hi Support, "Non-.NET/CLR Version of Sierra Chart. This version does not use the Microsoft .NET framework. Current limitations: Does not work with the OEC trading service. Spreadsheet functionality is still under development. This version is expected to become the main Sierra Chart version by October 2013." I wish to clarify that sierra charts main version as of now is capable; (a) to run on Linux OS without the need of having non CLR? (b) supports Linux OS and Spreadsheet Trading system is ready? Thank you. |
[2014-02-08 11:53:16] |
We have updated that information. The non-CLR version is not the main release yet. We do expect it will be out as the main release probably by April 2014. The new spreadsheet functionality is still under development . We are currently actively working on it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-09 01:28:23] |
The new spreadsheet functionality is still under development . We are currently actively working on it. (1) Can i request number of rows reduce to minimum at 2 (E3 & E4) instead of 10 rows at current setting? (2) Also may i request chart interval update reduce to minimum of 1 ms instead of 10 ms at current setting? The above request will load NEW Spreadsheet Trading System much faster using Rithmic Co-location connection. Thank you for your consideration. Date Time Of Last Edit: 2014-02-09 02:18:02
[2014-02-11 01:11:56] |
1. We will see about this. 2. This would be very detrimental to the functioning of Sierra Chart with the way that the chart update interval is implemented. You would not want to use such a setting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-11 01:36:37] |
I look forward to No.1 implementation in next release with the expectation that E3 and E4 input (2 rows only) instead of 10 rows would speed up spread sheet loading functionality. |
[2014-04-11 21:06:53] |
Futures Operator - Posts: 239 |
Do you have an updated timeframe on native Linux support?
Date Time Of Last Edit: 2014-04-11 21:08:02
[2014-04-12 11:10:39] |
We could not provide an estimate on something like this and at this point, we are already about four months behind on it. We thought we would start at the beginning of the year and we have not yet.
[2015-01-23 03:33:58] |
User386687 - Posts: 53 |
What is the current status for the Native Linux Support ? |
