Date/Time: Sat, 21 Nov 2026 11:11:48 +0000
cut Initial Balance lines at session end
View Count: 1085
[2020-09-25 06:20:20]
User884550 - Posts: 149
I have ETH chart 18:00-17:00 with IB set as attached, 9:30-10:29:59
but lines are extending into next ETH session, how to cut them at new session open?
imageEs IB.jpg / V - Attached On 2020-09-25 06:20:14 UTC - Size: 155.98 KB - 321 views
[2020-09-25 14:36:38]
The problem you are running into is that the Initial Balance study draws from the time of the Initial Balance to the next Initial Balance time.
The only way to do what you want would be to create a second chart that has session times from 09:30 - 17:00. Then use a Study/Price Overlay to overlay the Initial Balance study to the original chart. You will want to set the following in the Study/Price overlay:
- Bar Time Matching Method: Containing Match
- Fill Blanks with Last Value: No
