Date/Time: Wed, 08 May 2024 00:05:00 +0000
re: pivot points - daily indicator help...
View Count: 1045
[2014-02-07 20:51:58] |
User53765 - Posts: 66 |
Hi Sierra Support, Can you please tell me if its possible to add on the daily pivot point study indicator the ability to add r4.5 and s4.5 as a part of the other full list. All numerical half entries are shown from 1-3 pivot levels but only the 4th pivot level does not contain the half way mark. Can it be added to the indicator somehow? Thanks in advance. |
[2014-02-10 07:58:28] |
The easiest thing to do for now is to use the Study Subgraphs Average study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s164 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-10 14:50:45] |
Worked just fine. Thanks Sierra Support. |
