Date/Time: Sun, 28 Apr 2024 03:40:40 +0000
Is there a study that plots the price change since the open?
View Count: 461
[2020-09-24 22:38:11] |
gjockey - Posts: 47 |
Hello, In the studies list, I see a study called called "Percent Change Since Open". I am asking to see if there is a similar study that plots the $ price change since the open. Using the "Study Subgraphs Divide/Ratio", I am wanting to compare a study A against a study B "$ change from open". ie. I am hoping to plot [value of study A] per unit price change. Thank You. Date Time Of Last Edit: 2020-09-24 22:49:00
[2020-09-25 01:47:00] |
Hello SC, I just found an older thread ( Current Price Minus Open of Chart ) where my issue was touched upon "The closest is the Percent Change Since Open study: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s325 . We could create another study to calculate the actual change." Could you please consider creating such a study to calculate the net change from the open price (and also previous day close price). Thank You. Date Time Of Last Edit: 2020-09-25 01:48:38
[2020-09-25 04:33:03] |
Yes we will do this if we do not already have it. We will do this now.
[2020-09-25 22:13:22] |
Thank You. Your support is awesome.
Date Time Of Last Edit: 2020-09-25 22:16:58
[2020-09-25 22:51:53] |
This has been released and is in the current version of Sierra Chart.
