Date/Time: Sat, 04 May 2024 08:19:59 +0000
Trade Dom - unable to change color at Buy/Sell Columns
View Count: 1553
[2014-02-07 20:41:55] |
Viacheslav Malafeev - Posts: 88 |
Dear Support, I've spent quite a bit of time figuring out why some colors in Global Settings-Graphic Settings are customizable for my Trade Dom, and some are not. I can't customize Buy and Sell columns background settings, it's just not changing. Other color settings (like grid lines) changes without any problems. Here's the screenshot http://screencast.com/t/pmxcenmvLj Many thanks! Date Time Of Last Edit: 2014-02-09 12:46:57
[2014-02-10 08:01:52] |
This is a point that can easily be confusing. In the Graphics Settings window, you will notice that when you select Trade DOM Buy/Sell Column Background, there is a check mark option named "Enable". You need to check that.
