Date/Time: Fri, 03 May 2024 05:41:45 +0000
[User Discussion] - Kiwi Indicator lost in new ver 2171
View Count: 830
[2020-09-24 04:00:21] |
Willson - Posts: 176 |
Have used Kiwi indicator for many years. Now gone. It is now named "Kiwi_test_64.scsf_Tlnt This is also a changed or unrelated name. Can someone recompile this and furnish as it was in Ver 2135. |
[2020-09-24 06:59:43] |
What was the original name of this kiwi study?
[2020-09-24 15:46:18] |
Thanks, Original is hard to find, but it seems to be:"Kiwi12_64.dll" I think Kiwi updated it a year or so ago, maybe several years ago. I found a different name. name: "Kiwi_test.dll" They are probably the same function. Date Time Of Last Edit: 2020-09-25 02:50:18
[2020-09-25 05:56:09] |
That still does not give us enough information to work with.
[2020-09-25 08:22:30] |
User90125 - Posts: 715 |
@Willson Try sending a DM to Kiwi, and see if he can help you out: https://www.sierrachart.com/SupportBoard.php?do=UserProfile&UserID=46 |
[2020-09-25 17:38:53] |
Ackin - Posts: 1865 |
Willson) Studies should be part of Usercontributedstudies that everyone has in the new Sierrachart installation. One or two studies were taken by Sierrachart because they were problematic (I think NMinsBars was one of them) I have the Kiwi library repaired and without errors for SCH v2156, what version are you using now? v2171? Date Time Of Last Edit: 2020-09-25 18:50:29
[2020-09-27 00:55:54] |
I reverted to Ver 2135 to identify the function name. It is listed after SC function tree and just(below "User created Studies") The name is in an indented tree as shown below: * testKiwi* (Kiwi_test_64.dll V1881 Recalc T1 My need is for the T1 study. |
[2020-09-27 05:17:24] |
Compiled for SCH v2155+ Attached File btw. Recalc - Similar is the default Sierrachart study Chart Recalculation - Periodic Chart Recalculation - Periodic Date Time Of Last Edit: 2020-09-27 05:21:25
Kiwi_2151_64.dll - Attached On 2020-09-27 05:17:04 UTC - Size: 89 KB - 198 views |
