Date/Time: Mon, 06 May 2024 01:32:02 +0000
using word 'short' not allowed as variable?
View Count: 669
[2020-09-23 18:20:25] |
User681150 - Posts: 62 |
i get an error when i use the word 'short' as a variable. i change it to 'shortt' and everything works. see error message below. is this not allowed to use word short? : error: expected unqualified-id before '=' token 176 | float short = (sgmidline[sc.Index] < sgmidline[sc.Index-1]) float short = (sgmidline[sc.Index] < sgmidline[sc.Index-1]) && sgmidline[sc.Index] > -60 ;
[2020-09-23 19:47:17] |
Try using int16_t
[2020-09-23 20:15:59] |
John - SC Support - Posts: 31379 |
"short" is a specific type of integer and therefore is one of the keywords that you cannot use as a variable. Refer to the information here: https://en.cppreference.com/w/cpp/keyword For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-24 11:34:14] |
bradh - Posts: 854 |
https://en.cppreference.com/w/cpp/keyword So is "long". Since it is case sensitive, why not capitalize it as "Short"? |
[2020-09-24 22:20:51] |
Actually we just noticed that you are using "float short". That is definitely invalid. You would want to just use "short" only.
[2020-10-01 12:05:09] |
i tried using both int16_t and just the word "short". but i get errors int16_t short ;
test.cpp:233:9: error: declaration does not declare anything [-fpermissive] 233 | int16_t short ; | ^~~~~ short ; test.cpp:233:1: error: declaration does not declare anything [-fpermissive] 233 | short ; |
