Date/Time: Thu, 02 May 2024 14:50:12 +0000
SC holding old 'Set Default' values on new dll build
View Count: 510
[2020-09-23 15:30:22] |
User681150 - Posts: 62 |
in prev DLL builds i would "Set Defaults" in certain inputs to specific studies, so i didnt have to manual do it every time i re-built a dll when testing i made some changes to my default values in my acsil .cpp file and built the new dll. i noticed my new default settings from my acsil would not take (line coloring, width, drawstyle, etc). SC would still load the old settings even on a new DLL build. i would then have to "reset defaults", then set defaults again... to me this seems illogical (i can understand built-in indicators but not DLL files with potential new settings) just an FYI, not sure if this is what you intended on custom acsil Date Time Of Last Edit: 2020-09-23 17:00:16
[2020-09-23 17:47:03] |
If you are not removing the study from the chart and adding it again, then yes all of the Input Settings in the sc.SetDefaults code block are definitely not going to change back to defaults. Nothing has changed in this regard. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-23 17:47:27
[2020-09-30 21:51:51] |
thanks. But even when i rebuild the DLL AND remove the study and add it back in... it still picks up the "saved defaults". the only way not to use the saved defaults is either rename the dll OR click the "reset defaults". so removing and adding it back DOES NOT reset the defaults after rebuilding a DLL (my observations). some how SC is saving the settings based on the name of the study even after rebuilding dll |
[2020-09-30 23:51:34] |
Sierra_Chart Engineering - Posts: 14176 |
it still picks up the "saved defaults". Yes this is true.
