Date/Time: Sun, 28 Apr 2024 07:58:24 +0000
SC Version 2171 Market Depth Historical Graph Bug
View Count: 443
[2020-09-23 13:43:17] |
RIFT - Posts: 124 |
If in the Market Depth Historical Graph Study at CL_F the "Lowest Quantity for Coloring" is above 110 shows all levels, if it is lower, works fine.
2020-09-23_15h36_24.png / V - Attached On 2020-09-23 13:42:36 UTC - Size: 446.6 KB - 231 views 2020-09-23_15h35_01.png / V - Attached On 2020-09-23 13:42:52 UTC - Size: 230.56 KB - 180 views |
[2020-09-23 14:09:10] |
We will get this fixed. The reason it is occurring is because the value of 115 is more than the Maximum Quantity in the area that you are looking, and it is not updating properly. If you lower the value to be 1 (or more) less than the actual Maximum, then it will be correct. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-23 14:17:57] |
RIFT - Posts: 124 |
I am using 2x Market Depth Historical Graph Study on the same chart. In another study where the "Highest Quantity for Coloring" is set and scroll, the value changes automatically from the "Lowest Quantity for Coloring".
[2020-09-23 16:25:32] |
We have fixed this issue. This will be in the next Pre-Release (v 2173).
