Date/Time: Sat, 27 Apr 2024 07:55:59 +0000
R Trader Pro Plugin
View Count: 1368
[2020-09-22 16:27:54] |
Mathieu44 - Posts: 21 |
Can I use the R Trader Pro Plugin to get real time data on SC?
[2020-09-22 16:31:22] |
In other words, I sign into R Trader Pro. This gives me ability to use the feed with Bookmap. I contacted AMP Clearing and they said that SC might support a Rithmic plugin. So when R Trader is active, that data feed can support SC charts and I don't need to buy 2 feeds.
[2020-09-22 18:23:21] |
No this is not supported.
