Date/Time: Fri, 03 May 2024 10:36:18 +0000
Multiple Chart backup files in /Data folder
View Count: 369
[2020-09-22 10:03:58] |
User275592 - Posts: 97 |
Hi, without changing a parameter, i now get multiple back files in my /data subdirectory. like DAX 1.backup2092.backup2092 ... .cht is there a parameter to avoid this ? Thank you for your help |
[2020-09-22 10:49:34] |
Those backups are made just one time. If you do not want them just simply delete the Chartbook files: Chartbooks (Workspaces): Deleting a Chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
