Date/Time: Tue, 07 May 2024 13:01:08 +0000
Trade Evaluator
View Count: 574
[2020-09-21 22:23:55] |
ertrader - Posts: 645 |
Hi support, when connected to trade evaluator, sim mode is not able to be selected. I understand trade evaluator is a sim account but it's helpful to be able to execute trades without them getting counted in the evaluation. This happens on windows or wine. Interestingly, when running a replay, SC does enter sim mode as expected....sim mode is just not selectable in the menu /trade/trade simulation mode under normal operation. SC V2171 Date Time Of Last Edit: 2020-09-21 22:26:30
[2020-09-22 10:59:54] |
Yes this is a deliberate design so that there is no risk of someone doing trading which should be monitored and the server is not capturing the activity. If you want to do simulated trading just simply install another installation of Sierra Chart not using that service but instead using SC Data-All Services. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
