Date/Time: Mon, 06 May 2024 18:20:26 +0000
Show Chart
View Count: 382
[2020-09-21 13:38:36] |
User962067 - Posts: 11 |
Hello Sierra Chart support, I would like help showing the right side of the chart, which when scrolling from left to right does not show the entire chart on screen, attached image. |
2020-09-21_15-35-33.png / V - Attached On 2020-09-21 13:38:14 UTC - Size: 65.3 KB - 165 views |
[2020-09-21 17:43:48] |
John - SC Support - Posts: 31401 |
You must have the Lock Fill Space option set on. Refer to the following information: Chart Settings: Lock Fill Space (Chart >> Chart Settings >> Display >> Chart Display Items menu) Note that you can still scroll the chart to the right and continue to see the data, it is just not displaying in that section. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
