Date/Time: Wed, 08 May 2024 22:35:02 +0000
Volume Profile - volume numbers colors same as volume bars
View Count: 523
[2020-09-21 09:16:12] |
User882670 - Posts: 15 |
Hello is there a possibility to add coloring for Volume Profile - Volume numbers? Currently you can only color the volume bars - volume numbers are colored only with 1 color Also - is there a possibility to align volume numbers on the side of volume profile? (currently I have a workaround that I duplicate VP and display volumes on the other one with some fixed width etc) |
[2020-09-21 17:17:57] |
John - SC Support - Posts: 31480 |
You can change the color of the Volume Numbers within the volume profile by changing the color of the Subgraph named Volume Numbers Text Color and Size. Refer to the information here: Volume By Price Study: Volume Numbers Text Color and Size (SG7) There is no support for changing the position of that text that is drawn in the Volume Profile. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-21 19:40:48] |
Yes I know that you can change that color but that is only 1 color for whole volume profile. My request was to add coloring of the numbers accordingly to volume bars - is it possible? |
[2020-09-21 20:27:43] |
No, this is not supported.
[2020-09-22 10:15:57] |
I know, my question was is it possible to add it to some future update
