Date/Time: Mon, 06 May 2024 00:24:00 +0000
[User Discussion] - Replay window is not shown
View Count: 531
[2020-09-21 08:01:19] |
amirN - Posts: 159 |
The replay windows is not shown whenever I press the replay button or CTRL-R. It was working yesterday. How can I get it back?
[2020-09-21 08:12:13] |
Ackin - Posts: 1865 |
Maybe you have "Replay Win" hidden outside the active screen Try: Menu >> Window >> Reset Windows Reset Windows (Window)
This command resets the main chart window, all Values Windows, and the log windows to their default positions and size. Use this command if any of the windows are not visible. If the main window is not visible but shows up on your taskbar, then right click over the Sierra Chart icon on the taskbar and select Maximize. You can then select Reset Windows from the window menu. Date Time Of Last Edit: 2020-09-21 08:12:26
[2020-09-21 09:29:28] |
Thanks, for some reason when I loaded another chartbook the replay window was shown again.
