Date/Time: Fri, 03 May 2024 14:03:37 +0000
studies on overlay chart
View Count: 579
[2020-09-21 00:35:46] |
User425645 - Posts: 113 |
Hello, below ill post an image of an /es chart with /nq overlaid via overlay (bar) study. Is it possible to put a study on the overlayed /nq chart like a VBP for example, and how would i go about doing that? Thanks for your time |
[2020-09-21 16:15:32] |
John - SC Support - Posts: 31336 |
You really should use the Add Additional Symbol study to put the NQ on the chart, then most studies will work with the Add Additional Symbol. But, the Volume by Price and TPO are a few that will not work. Refer to the following for the Add Additional Symbol study: Add Additional Symbol Note the section in there entitled Basing Other Studies on Add Additional Symbol. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
