Date/Time: Thu, 02 May 2024 05:18:41 +0000
MES Sum Bid Pull/Stack not working until trade dom launched.
View Count: 702
[2020-09-18 18:06:58] |
FuturesTradeKing - Posts: 13 |
I'm on version 2159. I'm on the Denali feed. I have the NumberBarsCalcValue2 study with Sum Bid pull/stack and Ask Pull Stack displayed. I'm displaying ES on the left and MES on the right When I launch SC, the ES chart will update it's pull/stack values, but MES will show 0's until I launch a trade dom for MES with the column Pull Stack selected. Once I do this, then the values will begin. I attached 3 images. The first showing no values. The second showing the values after I launch the dom, and the third I show both graphs. ES on the left is fully populated, while MES on the right was 0's until I launched the dom. I don't think this should be the case, as I want to launch the program without having to open a dom. |
2020-09-15_07-06-28.png / V - Attached On 2020-09-18 17:57:07 UTC - Size: 115.85 KB - 241 views 2020-09-15_07-07-12.png / V - Attached On 2020-09-18 17:57:12 UTC - Size: 155.6 KB - 205 views 2020-09-18_10-55-46.png / V - Attached On 2020-09-18 17:57:20 UTC - Size: 194.59 KB - 227 views |
[2020-09-23 09:23:52] |
You do need to have a chart open which has the pulling/stacking market data columns for that symbol in order to access the values for them in other studies: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-23 14:40:38] |
Thanks. I'll add the Chart Dom to each chart and add pull stack values
