Date/Time: Sat, 04 May 2024 06:21:04 +0000
v2160 SetFloatLimits error with zero value on SCInput array
View Count: 395
[2020-09-18 09:59:11] |
binaryduke - Posts: 360 |
When compiling against the v2160 header, using the .SetFloatLimits function of the SCInput array results in a zero value appearing as 1.1754944e-38 within the inputs. Code: #include "sierrachart.h" SCDLLName("SCFloatInput") /*==========================================================================*/ SCSFExport scsf_FloatInput(SCStudyInterfaceRef sc) { SCInputRef Input_FloatInput = sc.Input[0]; if (sc.SetDefaults) { sc.GraphName = "Float Input"; Input_FloatInput.SetFloatLimits(FLT_MIN, FLT_MAX); Input_FloatInput.SetFloat(0); Input_FloatInput.Name = "Float Input"; sc.GraphRegion = 0; sc.AutoLoop = 1; return; } } Screenshot of input appearance attached. |
Screenshot 2020-09-18 at 10.54.05.png / V - Attached On 2020-09-18 09:58:33 UTC - Size: 64.4 KB - 174 views Attachment Deleted. |
[2020-09-18 10:08:56] |
Yes that does make sense based upon your code. Zero is below the minimum.
[2020-09-18 10:10:29] |
of course; -FLT_MAX is what I need. Apologies.
