Date/Time: Fri, 03 May 2024 13:31:39 +0000
Real-time data for Asian exchanges
View Count: 419
[2020-09-18 03:06:53] |
User19165 - Posts: 346 |
Due to Sierra's recent update that Osaka futures will not be proceeding within the barcharts Sierra feed. I am hunting for alternative data options that will work with Sierra. As I go through the data/trade services page, it lists CQG as a trade service only and it doesn't mention much at all about TT on that page. If I had a broker that routed through CQG or TT, would I also be able to get data through them that would be accepted within Sierra? |
[2020-09-18 10:01:53] |
Yes in this case we recommend using CQG.
[2020-10-27 06:23:23] |
Would this work: Open an account with AMP solely for the purpose of getting access to CQG data to feed into sierra, but all my trading from the charts is sent to Interactive Brokers. My reason for this is because AMP comm rates are more than 30% more expensive and so far their support to even answer basic account opening questions has been like pulling teeth. |
[2020-10-27 09:49:37] |
Yes you can do that. Refer to: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
