Date/Time: Wed, 08 May 2024 10:59:52 +0000
Spreadsheet
View Count: 463
[2020-09-17 17:59:22] |
Torsten Grüß - Posts: 45 |
I wanted to ask if the following entry setup can be implemented with SC spreadsheets. When I place an entry order, 10 more limit orders will automatically go into the market every 1% apart ? And only 1 stop to adjust the quantity |
[2020-09-18 03:24:17] |
Sawtooth - Posts: 3993 |
Theoretically it's possible, but very difficult to do, and not concurrently. Each order would need to be added sequentially. Each K3/M3 signal would need to be separated by a FALSE condition for the subsequent signal to initiate another entry. Each subsequent signal would need a new price in J22/J24. Bottom line: not really. |
[2020-09-18 10:01:00] |
You really should use ACSIL for this and not spreadsheets: Automated Trading From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
