Date/Time: Mon, 06 May 2024 17:34:00 +0000
fantom orders on chart
View Count: 480
[2020-09-17 12:28:58] |
User443396 - Posts: 4 |
My NQ chart shows an order that does not exit. When I exit a position a trade line connecting a non existent entry with my current trade shows up. How do I fix this? http://www.sierrachart.com/image.php?Image=1600345497699.png |
[2020-09-17 16:14:23] |
We do not know what you are trying to show in that screen shot. Is there an order in the Trade Orders list that is not actually working and you cannot cancel it?: Trading Information Windows: Trade Orders Window If you are referring to order fills, refer to: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
