Date/Time: Sat, 27 Apr 2024 22:18:23 +0000
SierraChartInstance_2
View Count: 445
[2020-09-16 20:22:32] |
Tom8toez - Posts: 29 |
I have a folder called "SierraChartInstance_2" in my main Sierra Chart directory. Is this something that can be removed?
[2020-09-17 00:09:05] |
Yes if you are not using sub instances (File >> New Instance) that is safe to delete.
