Date/Time: Sun, 05 May 2024 14:30:09 +0000
alert sounds are stuck in queue despite unticking option
View Count: 451
[2020-09-16 15:55:00] |
User686108 - Posts: 1 |
Hello, i have created an alert condition on the time and sales window that should give off one very short sound when a bid alert is triggered and another sound when an ask alert is triggered. The problem is that the sounds aren't playing as rapidly as needed as there is like half a second delay between them. I did untick the "Wait for prior alert sound to finish before playing the next queued sound" option in the global settings - but it makes no difference. Now the interesting thing is: I have tried a competitors programm on the same pc and it works flawlessly there. Could it be that the option that i've talked about is bugged? |
[2020-09-16 19:03:47] |
We would have to check but there may very well be .5 second delay between each alert. So this is just how it works.
