Date/Time: Mon, 29 Apr 2024 05:57:36 +0000
Tried to update daily bars - chart gets messed up (Bitmex)
View Count: 399
[2020-09-16 14:22:14] |
Calculus - Posts: 86 |
Hello I wasn't getting all my Bitmex data for the daily chart so used - Reload historical charts. I've done this multiple times in the past and it all worked perfectly, until today. What Sierra did was fix the day chart so it only updated to 2020-05-01, and I cannot change this value. See image. Any ideas? Thanks |
Screenshot - Sierra.png / V - Attached On 2020-09-16 14:21:32 UTC - Size: 97.88 KB - 164 views |
[2020-09-16 19:17:37] |
This is resolved. Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
