Date/Time: Fri, 03 May 2024 03:39:07 +0000
e-mini showing DPL for micro and vice versa
View Count: 426
[2020-09-16 11:15:03] |
User58008 - Posts: 32 |
Dear Sierra, I have problems with wrong displaying of DPL value in the Trade menu - in chart settings, when I choose to watch but trade different quote symbol, typically to watch e-mini NQ100 but trade micro NQ100, the DPL value shows wrong, I either see one null less in the result or one null more, so instead of having profit of $100, I see profit of $1000 and vice versa. Dont you know where the problem could be? Thank you |
[2020-09-16 12:38:35] |
seandunaway - Posts: 213 |
Statistics are calculated using the chart Symbol Currency Value per Tick and RT-Commission. Does it make more sense to calculate using the Trade and Current Quote Symbol instead, when used? |
[2020-09-18 10:25:08] |
Check this setting: Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) And the Commission should be coming from the Trade symbol. Just make sure you are on a newer version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-22 13:50:46] |
I think the Activity Log uses the Trade Symbol, but the chart header DPL uses the Chart Symbol's commission value, causing a mismatch?
