Date/Time: Fri, 03 May 2024 08:50:46 +0000
graphics
View Count: 466
[2020-09-16 04:32:09] |
User951413 - Posts: 12 |
Why are my graphics changing on theyre own. I cant get a white font on the scale. The trade lines on the charts keep changing. A lot of bugs on the graphics. |
[2020-09-16 10:37:01] |
This is not making any sense to us. How can this be? First of all, refer to the Graphics Settings window: Graphics Settings And then just pick one particular specific graphics issue you have and post an image of a chart and provide an explanation. Instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-16 12:28:20] |
ok ill slow it down for you. on a white chart when I set black text it does not stay black, the scale text for example goes white therefore I dont have prices that I can see, at first its fine, IT CHANGES to white suddenly. I go back to global setting and try to change it back, but this time it wont at all. this is one graphic issue |
[2020-09-18 10:26:05] |
Could you provide a video showing what you are seeing. You can attach it here. Instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile It is ok to attach a video being we asked for it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
