Date/Time: Sat, 04 May 2024 12:22:00 +0000
pivots
View Count: 482
[2020-09-15 14:41:59] |
User502256 - Posts: 1 |
How do i stop pivots from repainting
[2020-09-15 17:42:45] |
John - SC Support - Posts: 31362 |
Do you mean to say that the Pivot Points are changing as new data is included in the chart? If so, then you must have a Pivot Point Formula that has a calculation that involves the current data. There are only a few of these, and you will find the entire list of the Pivot Point calculations here: Pivot Points: Formula Types For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
